Application builder - function crashes after succesful build
I'm trying to build an application using the application builder in Labview 7.1. Application runs smooth in Labview. So does application builder. It's essentially a data logging application, reading from 2 com-ports and turning on and off some peripherals with a PCI 6503 card.
However, the .exe file created by the application builder crashes giving a memory error, some HEX-addresses and the classic "Send error report to Microsoft" window.
This far, I tried
1) building a simple application plotting random numbers - works fine
2) I'm using only one labcard (PCI 6503) so I removed code communicating with that card - still same error
Any hints on how to proceed?
(2,877 Views)
Hello Claes!
What error message do you get?
Have you tried to repair LV 7.1/ application builder?
Best Regards
Ashwani S.
National Instruments Sweden
(2,833 Views)
Hello Ashwani,
thanks for the input. I solved the problem. It was the "time delay" vi that was causing the problem. Once I located the error, it was easy to make my own vi doing the same thing, cut out all the time delays I had been using, and now everything works fine.
Cheers,
Claes O.
(2,827 Views)
