Application builder in LV8.2.1 doesn't works
i write a litte application including to vi's. Its works fine on the target system.
after make an exe file with appbuilder, close Labview and start the exe...it works too...
after that, i copy the complete folder to other pc's (Xp prof and vista).
the program starts on both systems without errors, but there' no activtation at the hardware... 😞
Environment: XP Prof. Service Pack 2
USB 6221 OEM
Labview 8.2.1
Runtime engine 7.1.1 and 8.2.1 installed on both systems
Driver for USB-Hardware was also installed with Measurement Explorer.
with Install-Procedure there's also no success.
In Application data folder is a dll located. Must I register the dll manually?
Hope anyone can help me...
Greetings HAL
(2,506 Views)
Hey HAL,
Do you have all necessary drivers installed on the target machine where you want the execuatable to run? Do you get any errors when running your exe? What do you mean with the hardware shows no activity? Just try to plug off the hardware and see if errors occur, because if there is no device you are entering in your executable there should be an error produced.
BR, Christian
(2,471 Views)
