Application builder problem...
I've built a .vi and have built it into a stand-alone application using the
application builder.
It didn't work.
When calling the manufacturer of the board I'm using they told me I need
to also include a .dll file. Which I then did using the application builder.
It still didn't work.
They then told me I need to 'register' the .dll file using an .exe called
'regsvr32.exe' found in the Windows directory.
The program finally worked!
However, I do not want each user to have to go through the pain in the *ss
of registering this .dll when I distribute the .vi.
Does anyone know how to have the application builder register a .dll?
Can I somehow call 'regsvr32.exe' and have it register during installation?
If anyone could
help I would greatly appreciate it.
Dave Neumann
Eaton Corporation
Phone: (414)449-6263
Fax: (414)449-6078
neumads@ch.etn.com
Message 1 of 8
(4,562 Views)
I finally went with a third party installer, InstallShield, to register my
OCXs and dlls. It was more reliable than trying to write my own
registration vi with the 'regsvr32' command.
I asked at NI Week if the LabVIEW 6i version of Application Builder
would register components. I was told it doesn't.
Alan Brause
"Dave Neumann" wrote in message
news:39a527bb@newsgroups.ni.com...
the
> It didn't work.
builder.
installation?
> If anyone could help I would greatly appreciate it.
> Dave Neumann
> Eaton Corporation
> Fax: (414)449-6078
> neumads@ch.etn.com
Message 2 of 8
(4,562 Views)
> It didn't work.
tion?
Dave,
There is an option in the LV 5.1 app builder that allows you to run
an executable after the rest of the setup is complete. Under the
Installer tab, select Advanced. I would think this would do what you
need, but as far as I know, you can only specifiy one executable to run,
not multiple.
Dave Thomson
David Thomson 303-499-1973 (voice and fax)
Original Code Consulting dthomson@originalcode.com
www.originalcode.com
National Instruments Alliance Program Member
Research Scientist 303-497-3470 (voice)
NOAA Aeronomy Laboratory 303-497-5373 (fax)
Boulder, Colorado dthomson@al.noaa.gov
Message 3 of 8
(4,562 Views)
I've tried that executable run option that you're referring to, and I
couldn't get it to work. Wonder if I'm the only one.
Mark
In article <39A575DC.A049396B@al.noaa.gov>,
David Thomson wrote:
using the
> > It didn't work.
need
builder.
called
the *ss
..dll?
installation?
> Dave,
run,
> not multiple.
> Regards,
> Dave Thomson
Sent via Deja.com http://www.deja.com/
Before you buy.
Message 4 of 8
(4,562 Views)
> Mark
I've used it successfully. Obviously not for the dll registration
program being discussed, but it does seem to run things for me.
Dave
3 (fax)
Message 5 of 8
(4,562 Views)
Same problem here
I have tried everything to run a executeble (both exe and bat files) after
instalation and it doesen't work.
Esben
wrote in message news:8o3v7s$dlj$1@nnrp1.deja.com...
> Mark
> using the
> > > It didn't work.
> need
> builder.
> called
> the *ss
> .dll?
> installation?
> > Dave,
> run,
> > not multiple.
> > Regards,
> > Dave Thomson
> Before you buy.
Message 6 of 8
(4,562 Views)
From the Application Builder Release Notes:
Install the file as part of your installation and
then run it afterwards to make the necessary modifications. The file
that you run must be one of the files that you install.
Maybe the problem is that you have to include the file to execute.
Jean-Pierre Drolet
"E" a �crit dans le message news:
39a6b567@newsgroups.ni.com...
> Same problem here
after
> Esben
> wrote in message
> > Mark
> > using the
> > > > It didn't work.
> > need
> > builder.
> > called
> > the *ss
> > .dll?
> > installation?
> > > Dave,
> > run,
> > > not multiple.
> > > Regards,
> > > Dave Thomson
> > Before you buy.
Message 7 of 8
(4,562 Views)
Aha!!! *light bulb* That must be the problem. 1) I didn't read that
in the Application Builder Release Notes and 2) I didn't put the
executable as one of the files that I installed.
Thanks. I'll check that out.
In article <39a8298e@newsgroups.ni.com>,
> Jean-Pierre Drolet
> > Same problem here
files)
> after
> > Esben
> > wrote in message
and I
> > > Mark
application
> > > using the
> > > > > It didn't work.
me I
> > > need
application
> > > builder.
..exe
> > > called
pain in
> > > the *ss
a
> > > .dll?
> > > installation?
> > > > Dave,
to run
the
what you
to
> > > run,
> > > > not multiple.
> > > > Regards,
> > > > Dave Thomson
> > > Before you buy.
Before you buy.
Message 8 of 8
(4,561 Views)
