Application builder return this error when building the application
This error is generated in the step "LOADING FILE":
LABVIEW ha provocato un errore di pagina non valida nel
modulo KERNEL32.DLL in 017f:bff7d76b.
Registri:
EAX=fed9f000 CS=017f EIP=bff7d76b EFLGS=00010207
EBX=81672784 SS=0187 ESP=00dcee20 EBP=00dcee44
ECX=fecc3c50 DS=0187 ESI=0000dbaf FS=4507
EDX=bffc9490 ES=0187 EDI=fed31280 GS=45a6
Byte all'indirizzo CS:EIP:
83 38 00 74 28 83 c0 08 46 3b f1 72 f3 be ff ff
Immagine dello stack:
00dcee44 00000000 00000000 ce114ff0 bff92e7f 81672784 bff7db0e 81672784 00000000 001f0003 bff8521c 81672784 ce114ff0 001f0003 00dcee84 00000000
I have in this target 32Mb PIII 666MHz W98 OS.
In my programming target i have 512Mb PIV 2,4GHz W2000 OS. I don't have
any error message in this target.
Is the just problem the little memory or is possible other problem?
Bytelabs.it
(3,046 Views)
It could very well be the lack of memory (32MB). The error you are getting is coming from the Operating System Kernel, there is litte an application can do wrong for something to go wrong in the kernel (lack of resources is one of those things). I would suggest finding another spare 32MB and trying it out (you should be able to pick this up for almost free now).
It could be another problem as well. If I were to place my bets, bad video card driver or bad memory.
(3,046 Views)
I'm trying to add memory (now is 96MB),the problem is resolved when i don't open all reference VI in the init phase.I open the referement when the VI is called.This method have resolt more problem but when i call all (16) Vi i have a bloc of computer .
I think a error in my code ,i'm trying to debug this.
If you have news or notice for VI_SERVER and reentrant execution thank for call me.
Best Regards Nicola
Bytelabs.it
(3,046 Views)
