Application builder
My question is about the application builder. I programmed a program for analysing data of a foot-pressure-system and at the end there is a diadem report build.
So my question is: Is there a possibility to build this program and run it on a computer where there is no diadem and no labview installed?!
I work with Labview 8.2 and Diadem 10. I already built such programs, but without Diadem and now i have the problem that there isn´t any data put on the report when using the ready application, although it works when using the normal VI.
Please help!!!
Thanks, Thomas
(3,226 Views)
Thomas,
you cannot run the VI or an application built with this VI on a machine that does not have DIAdem installed. You don't need the LabVIEW development system on that machine though - a LabVIEW runtime engine will do.
If you are using a compiled application, please consider that you have to manually add the report layouts to your installer definition. See this thread for more on that:
http://forums.ni.com/ni/board/message?board.id=170&message.id=254137.
Hope that helps,
Herbert
(3,184 Views)
Thanks, but now i only that it isn´t possible to do, which more or less is enough to konw 🙂
But the link you sent only shows our first "conversation", or did i something wrong...?!
Thomas
(3,154 Views)
