Application development
Hi All,
Is there any way to handle the different Instrument handler with single wire. Suppose we have 2 switch cards available in the system, can i access the both card with same instrument handler.
Also if in future i am adding some more devices (Like Serial/COM port) to the system. Is it possible to operate the new device with same handler .
Thanks in Advance
HKT
(3,641 Views)
Each device or session of use of the device has it's own session reference.
If you wish to group the, you could use a cluster of references.  You can then select the reference by name.
R
(3,621 Views)
Hi ,
I need to change the Cluster control whenever new device is added to system . Also device like CAN instrument handler is some numeric number (i.e. object IN) & switch is of some other type , is it possible to use both the device with same wire?
(3,602 Views)
Variant and LVOOP will allow diferent data types on the same wire.
Varienat put the work on the developer to interpret the data in the wire correctly.
LVOOP does it for you but you must adhere to the LVOOP rules.
Ben
BTW "LVOOP Rules!" Smiley Very Happy
(3,577 Views)
If you will need to make changes to a cluster, you should create a Type Definition of that cluster. Changes to the typdef control will propagate to all VIs that use that typdef control...
https://www.ni.com/docs/en-US/bundle/labview/page/creating-type-definitions-and-strict-type-definiti...
I'm not familiar with CAN instrumentation.
(3,575 Views)
