Application does start but not run
Hello there,
i have a problem with a big application (something between 1 and 2 Mb)
I build with the application builder.
Sometimes it does not run when i start it. it is visible in the
taskbar but the frontpanel does not popup. It was not possible for e
to find out when it runs and when the problem occures.
For finding out what happens I inserted into the program some one
button dialogs and the first one was placed into the first frame of
the main sequence. So it was actually the first thing that should be
done. But even this did not work when my problem occured.
Has it something to do with the size of the application?
And if so, how can I make it smaller? By using dll's?
Thanx for your answers!
(2,735 Views)
Milchbilch wrote:
> Hello there,
Hi Milc
hbilch,
I haven't had any problem like this yet. Maybe you could try to create
another simple top-level vi, which runs in a loop, just displaying the
current time. Inside this vi you place a control to start your
problem-vi. If the new top level vi runs, showing changing time, you
know exe files run on the target computer. Then start your problem vi
and wach the behaving. Maybe this helps to find out more.
Ciao,
Rainer
### Please remove all numbers in email address for reply ###
(2,735 Views)
