Application got slowed down
Hello every one
 I have written a code in labviw and
 I am running an application in a pc with 4gb ram, i5 processor .
Problem is the application is running slowly in this pc  .
When i am running the application i when to task manager to see the pc status please see the attached pic
When i go to another pc with 2gb ram it is too slow
So my question is
1 how to increase the application speed ?
2 If i integrate the VGA card does the application speed increases ?
Message 1 of 10
(8,119 Views)
You don't provide enough information to troubleshoot the problem. CPU use can be high if you have polling UI loops without small waits. Memory use can be high if you have huge data structures and many data copies in memory (e.g. overuse of local variables or generally inefficient code).
Please define "slow". Do the computations take more time that you think they should or does the user interface feel sluggish? How do you measure the slowness?
What does the program do? Please show us some code!!
Typically, it does not help to simply throw more CPU power at the problem if the root cause is in inefficient and wasteful code. A faster CPU will simply waste even more clock cycles per unit time. 😄
Message 2 of 10
(8,101 Views)
I dont thinks that labview installer file is slowing down.Please attach your code. It needs some refinement.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 3 of 10
(8,083 Views)
Greedy loops.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 10
(8,061 Views)
@Yamaeda wrote:
Greedy loops.
/Y
Most likely...  greedy loops.   On top of bad architecture.
And since we're guessing:  how about Local & Stacked Sequence Structure abuse 😄
Message 5 of 10
(8,046 Views)
We cannot rule out Localitis and Sequentitis, but the symptoms have yet to reveal themselves. However the high cpu usage and inability to get a responsive system clearly suggest a greedy loop, which we lack a good name for.
I suggest Capitalismus, Bankeris or Electronic Artosis (nudge, nudge, know what i mean?)
/Y
Qestit Systems
Message 6 of 10
(7,956 Views)
I should have been more clear.  😄
Definitely greedy loop.
Other things to look for is the architecture and the possible abuse of variables and structures.  😉
Message 7 of 10
(7,935 Views)
Grreedy loops are definitely only part of the story, they don't consume 1.2GB of memory. 😄
Message 8 of 10
(7,921 Views)
I think the problem is with your PC, or at least Windows task manager.  How can you have a task taking 1,24,368 KB?  There seems to be a digit missing in the middle.
Message 9 of 10
(7,910 Views)
So, what exactly is that "SIT Awareness sys.exe" and what does it have to do with LabVIEW? There must be a reason you highlighted it for this thread.
If this is your LabVIEW application, please tell us if you have similar problems when running in the development system.
Message 10 of 10
(7,898 Views)
