Application.ini : useLocaleDecimalPt=False
Hi all,
I've been wondering for a while now.  Everytime I build a application and an installer, a standard application.ini is made with some standard values in there.
I can't seem to figure out why I always have to copy useLocaleDecimalPt=False in there.
Is there a way to solve this?
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(4,498 Views)
Accepted by topic author ABCPrograms
Hi Bjorn,
make an application.ini with all keys you want to have.
Then add that ini to your project.
Then choose that ini in the apbuilder to replace the standard aplication.ini with!
(4,488 Views)
Hi Gerd,
thx for the answer m8, and indeed that is a solution for most of the programs.  But sometimes you need specific keys and then you still have to munually update your ini file.  It would be easier I guess if you could select in the app builder whick keys it should use and which one he doesn't.
Thx a lot m8
Kind regards,
- Bjorn -
(4,486 Views)
Hi Bjorn,
even if you need some specific keys for your executable - usually those keys stay the same for that executable.
So (usually) you have to create an ini only once per project (or per appbuilder setting)...
Yes, having a "click and make" tool in the appbuilder might be fine - but we always have the Idea Exchange for such suggestions Smiley Wink
(4,483 Views)
Already posted in there today 😉
Thx again Gerd
Kind regards,
- Bjorn -
(4,481 Views)
