Application limit to 1G memory allocation
after all i'd search for methods to reduce the amount of data and to optimize algorithms (well, >2GB is a LOT of data... )
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 11 of 14
(772 Views)
In the following article http://zone.ni.com/reference/en-XX/help/371361D-01/lvhowto/enable_lrg_ad_aware/ there is an explanation how to access 3G and even 4G memory with Windows XP.
Is it referring to Labview 8.5 only? Is it relevant to Labview 8.2?
Does anyone succeed to gain 4G memory?
Regards
Gabi
Message 12 of 14
(757 Views)
LV 8.5 only. LV8.2 and below were only 2GB applications.
Jarrod S.
Message 13 of 14
(746 Views)
Windows, by default, sets the upper 0.5BBytes of the 2GByte memory space aside for system code.  So, in getting 1.5GBytes, you have probably reached your limit.  Check out Managing Large Data Sets in LabVIEW for more information.  If you need more than 1.5GBytes, there are options, but you will take a speed hit.  The easiest is to use a disk cache.  Next on the list is compressing your data in memory.
Good luck.
Message 14 of 14
(710 Views)
