Application occasionally writes 0KB file on the server (remote computer)
We have multiple computers running LabView applications and each computer writes result file into a server (remote computer).
Occasionally we are getting files that has no contents (0KB) and it is happening randomely. - each computer writes files in different folders.
It seems the case that when there is a heavy load to access the server from multiple computers it more likely happens.
Hense I wonder if there is any good practice to follow when multiple application access a server to write files simulteneously.
Thanks.
(2,628 Views)
Hello
-           Please check these two links below.
-          http://www.ni.com/white-paper/4433/en#toc7
-          https://www.ni.com/docs/en-US/bundle/labview/page/viewing-and-controlling-front-panels-remotely-with...
Regards
(2,604 Views)
Thanks fromm8,
That link was interesting and pretty sure that I need to study further.
However my server does not run LabView application at all. (It is not LabView Client - Server application.)
The configuration here is just multiple computers accessing a server to create file using "Open_Create_Replace File.vi" and write data using "Format into File".
Creating File seems always work but writing data occasionally misses. (no data in the file)
Thanks.
(2,592 Views)
