Application on Win7 64bit throws error -50103, but not on Win XP 32bit host
LabVIEW application newly installed on Win7 64bit host throws error -50103.
Same aplication deployed from same installation disk on Win XP 32bit host have been working for 2 years withourt problem.
I did have a problem with importing the MAX configuration from the Win XP 32bit machine to the  Win 7 64bit machine.
My solution was to install all the drivers from my most recent Devaloper Suite 2012 DVD.
After that the executable did run fine, except when the variuos DAq tasks are executed for the second time in a loop it thows error -50103.
If i click ok on the erro popup, everything else works fine until in the next pass of the loop I get the same error.
Why would I get error on one host but not on the other one?
How do I fix this?
Scientia est potentia!
(2,488 Views)
A common error that you can find numerous posts about with a search
http://forums.ni.com/t5/forums/searchpage/tab/message?filter=location&location=forum-board%3A170&q=5...
(2,478 Views)
