Application reference to local/remote machine
Yes, may be there is a firewall installed which doesn't allow a TCP communication through port 3363 (used by default) or something else. You can change this value in VI Server configuration.
Message 11 of 13
(780 Views)
Hi Waldemar,
I am having same Error 63 problem and I wanted to ask you about firewall.
Since I don't know anything about it can you tell me where to go to find out if I have firewall ON, and if it is there where is the place I should go to remove the firewall from the list of the ports you stated above.
I appreciate your help,
Pedja
Message 12 of 13
(567 Views)
Hi Sheela,
Can you tell me where to go to remove the firewall from the ports if there is one on my computer at all?
Pedja
Message 13 of 13
(567 Views)
