Application runs slowly
I created for remote real time data display that reads data off the ethernet
and then performs some proceesing to convert the raw data to engineering
units. I then created an apllication so that I could run this program on
several (Apple) workstations. I would run two of these apllications at one
time since I was reading data from two different sources. This worked really
well. Recently, the workstations were changed from Apples to PCs running
windows NT. I recreated the applications and ran them on the PCs. I have
noticed that the applications now run much slower. I can bring one of the
windows in the foreground and this window will run alot quicker but theother
window is much too slow. If i put both windoes in the bacgr
ound, they seem
to run at the same speed, but it still is much slower than on the Apple.
What can I do to optimize the speed of the applications?
(3,776 Views)
"Dawn Davis" wrote in message
news:3a8bdbd1@newsgroups.ni.com...
> window is much too slow. If i put both windoes in the bacground, they
seem
I've been fighting with application speed problems myself for the past
little bit. I love to see discussion of this, because the NI devzone has
very few suggestions. Lemme throw out a few general thoughts on ways to
improve speed:
* Check the VI Options (edit a VI, right click the icon in top right corner)
and there's a tab for execution parameters. Read up on the options, they
adjust the execution priorities. This could solve some of your problems. In
my case, it didn't help a lot because I wanted to adjust priorities among
loops in my event-handler, not of subVIs.
* Parallellize your application by putting seperate events into seperate
while-loops. In most cases serializing work is a real slow thing. Labview
can decide when no data or control hazards exist, whenever possible it will
execute stuff in parallel. Be forewarned, in many situations globals and
locals will create all kinds of unforseen data dependancies between parallel
while-loops. Be conscious of the underlying multitasking, Mac Unix and
Windows handle things differently as described on the NI website.
* Spinning while-loops make REAL SLOW code. The timer-icon is one solution
but not a very good one. I saw an order of magnitude speed increase changing
my code to use the notify VI's set to never timeout. If this is right in
your situation, by all means switch! The polling scheme serializes things
too much. Event-messaging will let the system execute important things while
other sections wait.
* Unforseen factors will change things, especially priority for the
foreground application. One solution might be to change to the GOOP model
(www.ni.com/goop). If written correctly, it should be easy to access each
instance of the program as a seperate object. That way you'd never have a
second app in the background, it would run out of a single application. This
will also help eliminate tricky globals which helps create parallelism. The
goop vi's really don't add much overhead, in my experience.
* Modify algorithms to be more efficient. Consider hiring some college
undergrad fresh out of an algorithms course to calculate your Big-O
complexity on algorithms. Fix those problems with better data structures!
Labview will re-size arrays and structures but this is very slow, always
prevent this from happening by initializing the array and not resizing. Get
the professional version which has the VI profiler to check what's slow.
Amdahl's law, make the common case fast!
* Look at the machine you're running it on. Labview is memory and processor
hungry compared to something like C++. My company's app is pretty large and
runs ok on a Celeron P400 with 128 meg of ram. There prob will be problems
if the computer is memory starved, possibly the case since you said two
copies are running at once.
* Move to 6i for any large app. The front-panel control reference is
absolutely invaluable for complex programs. I cannot believe people could
work without control reference.
* Some events are just dog-slow, for example polling the mouse properties in
a picture indicator, or polling a front-panel control to see if it's changed
since the last loop iteration. Running these in a lower priority loop might
help, but I've never found a good solution.
That's just my quick thoughts on the issue. Email me or post follow ups, I'm
always interested in this topic.
-joey
(3,776 Views)
Joseph Oravec wrote in message
news:3a8c4a88@newsgroups.ni.com...
Get
Careful with this. I'd always been doing this, reasoning that even if it
wasn't quicker in every case than having Labview automatically extend arrays
on auto-indexing, it should not be slower. However in a test with a for
loop, bringing an array of numbers out, the autoindexing approach was twice
as fast as the preinit/replace element scheme. This was on both small and
large arrays
I recall comment from Greg a while back saying that where it was possible,
Labview did reallocation of the whole array before starting the loop; with a
for loop, it's possible to work out in advance how much memory is needed and
Labview does this on the fly. Even if you're in a while loop where it can't
allocate the whole array, increasing the size doesn't entail allocating a
new block of memory and copying the old array across to it, as I once
thought.
I've been meaning to do some more tests with this, and certainly before I
write anything else from scratch where it may be relevant I'm going to try
both approaches with a skeleton program and see which approach is better in
each case.
(3,776 Views)
"Craig Graham" wrote in message
news:3a8c4eae@newsgroups.ni.com...
structures!
arrays
twice
> large arrays.
This is amazing, I believe you if the profiler said so; I just don't know
how that can be true. Everything you read in books or webpages says to use
pre-init/replace. Maybe somebody who works on the underlying labview engine
could pop-in and explain the results.
I intended my original comment more to watch out for nasty complex
algorithms. Spend the time on those algorithms and cut that n^2 time down to
n*logn where possible. Maybe I'm the only Labview programmer in the world
who does this, but usually I'm lazy the first time through and want to get a
working prototype. Go back and reduce computational complexity and that'll
help.
a
and
can't
> thought.
That makes sense. There's lots of "loop-unrolling" style techniques that
they could implement, so it's totally believable. It really isn't hard to
look some loops, figure out how many times it will run, and work out a lot
of factors in advance.
On the other hand with my real-life results labview is even pretty stupid
about redundant calculations. For example, it didn't even automatically move
a sin-cos calculation outside of a loop for me. This added seconds to a
calculation of mine because the trig ended up executing N^2 times. Dragged
it outside and voila only a single execution per call.
One surprise I might throw in. The formula nodes did NOT seem any different
in my experience than the equivalent icon-primitives. However on Labview 5.1
calculations didn't seem optimized at all. First case was some long equation
which didn't take too long. Second case was the similar equation but broken
into several smaller more readable chunks which took a lot longer. The goal
was to make a more readable formula node, but labview didn't optimize out
un-used values apparantly.]
I got an email from somebody immediately after my posting about the "Wait"
being very necessary in while loops on NT. This prevents while-loops from
the popular sit-and-spin taking up system processing resources. Thought I
had mentioned it originally and it is a pretty basic idea, but perhaps the
clarification is necessary. It is not a cure-all but will prevent small
loops from stealing time from useful functions.
-joey
(3,776 Views)
news:3a8cc72d@newsgroups.ni.com...
engine
I didn't use the profiler- very simple test. Just have a for loop that
passes out an array of integers generated by the iteration count of the for
loop. Take the timer value before and after the loop and subtract them. Make
the array large (I used 100,000 elements) so the slight
timing error caused
by the OS (NT in this case) ticking over is insignificant and compare the
times required to create the array with autoindexing and with pre-init. Easy
enough for anyone to try.
(3,776 Views)
