Application still shown in taskbar after closing executable
I've seen a couple other threads on this subject, but they did not offer a solution. I'm not sure if the taskbar entry will eventually go away or not. I've only waited a minute or two before ending the task in Task Manager.
My front panels appear to close, but my top level VI doesn't really have a front panel so I set it to be hidden. I have to end the task before I can run the EXE again. Thanks,
(5,385 Views)
It can sometimes takes a bit for the Run-Time Engine to unload, especially if the application is large. That's assuming you don't have a loop that's simply not stopping. Does your application have a main loop, and do you know if it's actually stopping?
(5,382 Views)
A hidden front panel will keep the application alive.
To end an executable all front panels must be closed!
So in the termination code of you application you should close the front panel of your hidden VI (use the 'Close FP' method).
That should do it.
Ton
My LabVIEW Ideas
(5,353 Views)
Thanks Ton! That was the answer. I guess in development mode Labview closes the front panel for you...
Shane
(5,303 Views)
 How about if the user closes the panel with the "X" ?
(5,065 Views)
Hi dbtestcon!
Are you talking about closing the panel with the "X" in the development environment or an executable?
Kristen H.
(5,051 Views)
Executable.
I've played with it a few ways but never spent enough time to address it.  Instead of having the default Top Level Application settings, I customize the VI properties and take away the ability for the user to close the window....
(5,049 Views)
