Application using Config files
As I am new to Labview.I need help as to how to use configINI file for my application.I have already made the read and write configuration Files as a sub Vi.Can anyone send me an example program using config file subvi in an application.
(3,276 Views)
Check.the link in my signature. There is a post titled: "Don't recode, reconfigure". Start there and work your way forward.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,257 Views)
If you already have read and write sub vis then what is the problem? There are examples of using config files in the Example Finder (Help->Find Examples) and lots of good data in the documentation.
Obviously something is not working or you wouldn't be posting. Tell is what trouble you are having, post your vi (or a vi snippet - Edit->Create VI Snippet from selection) and describe what you tried and what problem you had. You will probably get more helpful replies.
(3,227 Views)
