Application web server error and access logs
There is a knowledgebase article here that describes how to enable, find, and view the error and access logs for the built-in web server under LabVIEW 2009.
My question is related to the Application Web Server in LabVIEW 2010:  I would like to know if there are equivalent logs?
James
(2,706 Views)
The information in the KnowledgeBase that you linked appears valid for 2010 as well.  In terms of the features available with the Web Server for stand-alone applications, the LabVIEW help will be one of your best resources.  I hope this helps!
- Greg J
(2,676 Views)
