Application with excel does not work after installing. Cause is excel report generation
First of all, yes i have selected the installer and included the NI report support. I can run and install the application buth the application freezes when handling an excel-related VI. I can still run the program in Labview and it works fine buth i want to use an exe because i have seen that it works considerably faster.
Andries Wim
(2,768 Views)
I won't be able to help you with the Excel problem. I do not like Active
X and don't deal with it if I don't absolutely have to.
But your claim that the executable runs considerably faster given the
same hardware and system resources definitely sounds suspicious. LabVIEW
has very little speed difference between the development system and an
executable. The difference is so small that you almost never should be
able to even notice it. If it is very notica
ble there are other reasons
that it is faster, for instance failed initialization for whatever
reasons, which makes subsequent functions to simply skip their task
instead of doing something.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,768 Views)
What version is your report generation toolkit?
If it's version 1.0.1 or under, please follow the instruction here
Dan
(2,768 Views)
