Apply Changes to Mulitple Items
Say I want to set the state to disabled for multiple controls or indicators.  I tried selecting a set and right clicking, but that only brings up properties for the individual control I r-clicked on.  Is there a way to "group" items, and perhaps change a common parameter?
(2,864 Views)
Unless you place the items into an array (which you probably don't want to do) or a cluster you can only set the properties one control at a time.
(2,848 Views)
You could probably write a tool to do this (using the Selection List[] property for the panel\pane), but you should note that not all objects on the panel will necessarily be of the Control class.
___________________
Try to take over the world!
(2,842 Views)
