Apply a border to the chart in HTML report
I am generating an html report as the final output for my LV program. I have a few graphs that i have added to the report using the append control image to report tool. I have set the image on the control panel to be transperent so that it is printer friendly when i print out the html report. Everything works fine but there is no border around the axis, i.e. there is no solid line that defines x axis and y axis for the graphs. Is there is a property tool that can be used to set this?
(2,670 Views)
I have used this trick alot. One thing that I found is that if you make the color inside the graph white instead of transparent you will get the results that you are looking for. I usually make the outside of my graph transparent and the inside of my graph white and it looks good.
Hope this helps
Joe
Joe.
"NOTHING IS EVER EASY"
(2,670 Views)
