Apply custom scale and add bolean so I can log on demand
Hey Matt!
It worked! Adding min and max to the AI Current DAQmx was what solved the problem! Can't believe that was what made all the trouble. You have been such a great help! I would like to mark it as solved since you actually solved the two problems I had to begin with which was the scale and the bolean. Should I do that even though I would still like you to help me out with the timestamp? That example you showed me seems very complicated and I can not really understand why I would need to add all those "Write to TDMS" functions.
Many greetings
DP
Message 21 of 22
(865 Views)
Thats great.  Proper forum etiquette would be to mark the solution for this thread and then begin another one Smiley Very Happy
We do that to try to keep it neat and orginized so other people can search for solutions.
There are a lot of extremely helpful people on the NI forums and im sure ill see the new thread as well.
-Matt
Message 22 of 22
(860 Views)
