Apply velocity to wheels Vs. apply velocity to motors
Hi all,
I need to send a velocity command to a robot (E-puck2). It has fixed wheels so I built a diffrential steering frame.
How should I know which one of the VI's will result in an accurate velocity command, "apply velocity to wheels" or "apply velocity to motors"?
Right now I use "apply velocity to wheels" but the velocity control is not good, and I'm trying to figure out whether the problem is there.
Thank you
Orit
Message 1 of 8
(2,872 Views)
Another remark,
The E-puck2's motors are stepper motors, their input is steps per second. Does it change the answer?
Message 2 of 8
(2,860 Views)
And another remark,
I just paid attention that in the "create wheel" VI I use, there is a note about the wheel parameters - labview will use the gear ratio and the wheel radius only if I use the motor communication input. I didnt use the motor communication at all, so I must recieve wrong data because of that?
Does using or not using motor communication change the answer to the question about choosing between "apply velocity to wheels/motors"?
And in general, how do I know if I need to use motor communication or not?
Thanks again for any help!
Orit
Message 3 of 8
(2,831 Views)
What is the difference between "Apply velocity to wheels" VI and "Apply velocity to motors" VI?
 Why prefer one to the other?
Thank you in advance
Message 4 of 8
(2,777 Views)
What is the difference between steering frame velocity and arc velocity?
When do I use each one of them?
Thank you
Orit
Message 5 of 8
(2,802 Views)
I'm asking according to "apply velocity to motors" VI...
Message 6 of 8
(2,730 Views)
Hello all,
Since I find it difficult to find a solution for long time,
I will be glad if someone can recommended where can I ask my questions:
In LabView Robotics,
1. How can I choose between "apply velocity to wheels" VI and "apply velocity to motors" VI?
2. According to the those 2 VIs, what is arc velocity and what is steering frame velocity?
Thank you very much in advance
Orit
Message 7 of 8
(2,729 Views)
I'm guessing that, like me, many people here cannot answer such a specialized robotics question because it's not really a "how to do you do this in LabVIEW" question, but more like, "what do these specific toolkit VIs do?"  😞
Bill
CLD
(Mid-Level minion.)
Message 8 of 8
(2,692 Views)
