Applying Library Icon bug (or Feature request)?
I am curious if NI would consider this a bug, or if it should be a feature request on the Idea Exchange.
I typically have some small footprint VIs in a library/class/etc (i.e. they have a small icon).  In these cases I don't like to use the library icon.  In the Icon editor, I simply hide the NI_Library layer, and everything is fine.  Except, if I make a change to the library icon, LabVIEW, makes the layer visible again.  I am guessing that LabVIEW is actually deleting and adding the layers.
Regardless, shouldn't LabVIEW check the visbility status of the layer and keep it intact after the update?
This is all in LV2011.
(4,365 Views)
Hi Matthew,
I tried to duplicate this behavior on my machine and it seems to be a bug.
I'm going to create an CAR (correction action request) and I'll give you the update for this error.
This is the number of the CAR so you can keep track of the bug for future releases. CAR : 349073
Thank you so much for helping us to improve LabVIEW.
Have a great day,
Miguel Fonseca Applications
 Engineer National Instruments
 http://www.ni.com/support
(4,331 Views)
