Aquarium Automatic Water LEvel Control
This looks like it would do the trick! It's clean and efficient. However, good LabVIEW coding practice is to avoid using local variables unless absolutely necessary, as they could cause unwanted race conditions. The one change to the above snippit that should be made is to wire the output of the "less than" node directly to to stop condition in the loop instead of using a local variable there. Nice, though!
Message 11 of 16
(2,213 Views)
I know it's not nearly as sexy - or fun to do - but I wonder if a toilet float system would work?
Bill
CLD
(Mid-Level minion.)
Message 12 of 16
(1,549 Views)
hi
can i get the block anf front panel of this tank file
thanks
Message 13 of 16
(1,358 Views)
@sahar420 wrote:
hi
thanks
So you can use this for your homework?
Bill
CLD
(Mid-Level minion.)
Message 14 of 16
(1,353 Views)
can you plz explain how does it work?
Message 15 of 16
(1,317 Views)
It simulates an aquarium where the water evaporates and when the water reaches a certain level, more water gets added until the tank is full.
Bill
CLD
(Mid-Level minion.)
Message 16 of 16
(1,313 Views)
