Aquisition of data from Labview to Arduino
I Have to recover the temperature from Labview to Arduino, is it possible to do it ? In all my research I just found that we can recover signals from Arduino to Labview and not the opposite ?? Because of the lack of materiels I have to do it and it is about temperature. So i send degrees to Arduino and after that I manipulate the temperature on Arduino to do another things...
Please could you answer to my question ?
Thank you,
SC
(2,545 Views)
Hi Soucha,
communication between LabVIEW/PC and Arduino is based on a (virtual) serial port.
You can easily use VISAWrite to send data to your Arduino running your own program routine…
(2,529 Views)
Thank you for you answer, I will make research on the digitalwrite of Arduino on Labview ^^.
Your answer helped me a lot.
SC
(2,515 Views)
