Arbitrary signal conversion
Hi!!!!
I am ABHRO from Banglore,India.I have made an arbitary signal from the data points I am having and now I need to convert that signal to another form of which I know the relation(I mean the equation).
I wanted to know if there is any procedure to convert the input signal to another form and further use it.
(2,623 Views)
Couldn't you just
input array -> equation -> output array?
Kudos and Accepted as Solution are welcome!
(2,604 Views)
