Arduino HX711 Interface
Ok, i have arudino UNO connected to HX711 board, i have LINX package installed and able to communicate with arudino, however i can't found a way to read the hx711 load sensor output in to lab view (because of it's analog output) i did searched the forums and found that this is unsolved problem
https://forums.ni.com/t5/LabVIEW/Connect-Hx711-in-a-NI-USB-6009-or-Arduino-UNO-in-the-Labview/m-p/30...
https://forums.ni.com/t5/LabVIEW/labview-code-HX711/m-p/3217221
on the other hand there seems to be someone who did managed to do that
https://www.youtube.com/watch?v=Z3BCwk7Z7tI
as you see in the video, i want to do exactly as in that video, sadly he didn't post and code or vi to learn from, so help is really needed here
thankyou
Message 1 of 8
(6,230 Views)
The Arduino reads the load cell.  You use VISA to get LabVIEW to "talk to" the Arduino and get it to send the values it is reading to you over the VISA port.  You then use LabVIEW to display these values using a nice Meter representation as shown in the video.
I've not looked at the LINX software, but I have used LabVIEW and VISA to get data from an Arduino board.  It really isn't very difficult.  Give it a try, and if your code is giving you results you do not understand, write back, and attach your code (meaning the VI itself, not a useless picture of the Block Diagram or Front Panel).
Bob Schor
Message 2 of 8
(6,219 Views)
so, you are telling me there is no way to do that using LINX? Also i'm using LV pro to output my VI as portable exe, i don't think using VISA assure me that!
Message 3 of 8
(6,190 Views)
No, I'm telling you that I, personally, have not used LINX, so cannot advise you about that.  However, I have successfully used LabVIEW to get data from Arduino using tools from the LabVIEW Tools Network.
I don't understand your second sentence.  I don't know what "LV pro" means, and I haven't seen (and cannot evaluate) your "VI".  Why don't you attach your VI so we can see it and better understand what you are trying to say?
Bob Schor
Message 4 of 8
(6,185 Views)
ok, i think i'll wait for someone who use LINX or "Labview interface for arudino" for providing a solution for that problem
thank you for reply
LV pro = Labview professional
Message 5 of 8
(6,177 Views)
Hi Bob, could you please share your vi to understand that how you have connected.
Message 6 of 8
(4,975 Views)
Wow, I'll have to go back to the archives!  A student whom I was helping decided to use Arduino to build a "touch sensor" (the alternative was a pair of small pressure switches, such as what you'd have under each key on your keyboard).  I think he was just intrigued at using a "microcontroller" (it was a pain in the rear end to use, and definitely cost more in time and effort, not to mention robustness, speed, and reliability, than one of NI's small USB DAQ devices).  He graduated four years ago(?), so the code is even older ...  I'll look, but can't promise I'll be able to find it (it certainly isn't on my laptop ...).
Bob Schor
Message 7 of 8
(4,967 Views)
This makes no sense.
The only way to connect to the Arduino Uno from a PC is via the USB cable that is often shipped with the Arduino Uno.
There are plenty of tutorials showing how to connect the HX711 to the Arduino Uno.
The rest is coding.
You should do some work / research instead of asking for a solution to be handed to you!
Message 8 of 8
(4,964 Views)
