Arduino-LabVIEW Serial connection (shutting down computer)
Is the serial monitor a different physical connection, or just a different piece of software?
Message 11 of 14
(1,155 Views)
the serial monitor is part of the same arduino software, just a pop in window to display the results.
both arduino and labview using the same port.
but i guess i figured out the problem as i got a message usbser.sys
USB serial driver (Usbser.sys)
i looked in my computer and i didn't find this driver, so i need to install it.
Message 12 of 14
(1,152 Views)
the Solution is updating the drivers and install all the missing files.
now is working properly.
Message 13 of 14
(1,143 Views)
Then you should mark Wiebe's message #7 as the solution to your problem.  He was the one who suggested out of date drivers and to update them.
Message 14 of 14
(1,130 Views)
