Arduino Servo + Button
Hey People!
Programm in Picture 1 does work: if i press the button the DI Value Indicator blinks.
Programm in picture 2 does work: if i set a number higher than 2, the servo moves, if i change to a number lower than 2, the servo moves again.
Programm in picutre 3 doesn't work: I just get different unspecified errors.
Does anyone have an idea where the problem is? Help would be so much appreciated!
(1,985 Views)
Accepted by topic author howhuge
To start read point number 5 on this FAQ. You only have one connection to the arduino.
Hope this helps
Now Using LabVIEW 2019SP1 and TestStand 2019
(1,948 Views)
Thank you so much! I changed the code considering this and now it works. Have a nice sunday! 🌞
(1,920 Views)
