Arduino connected to sbRio 911 seriell port by using LabView Software
i want to connect an Arduino Uno Developer Board to a NI sbRio 911 FPGA board. The Arduino will be connected to the Seriell Port J1 on the sbRio.
My Problem is, how can I use the seriell Port on sbRio in LABVIEW? I can´t find the right Port for the communication. Can someone please help me?
(3,362 Views)
HI,
look into this tutorial:
http://www.ni.com/white-paper/9595/en/
hope that helps...
Anna
Anna Vogl
Certified LabVIEW Developer
(3,289 Views)
Thanks for your help 🙂
One question I have, what is the name of the port J1 in the Labview software?
In the example usually is something like Port8/DIO0, what is this name for the serial port J1?
(3,274 Views)
I'm not sure. I think you can add every possible FPGA I/O to your project. Hopefully the name is J1 🙂
Anna Vogl
(3,266 Views)
But I don´t want to connect FPGA I/O. I want to use the serial Port for communication to an Arduino Uno with the RS232 Protocol....And therefor I have to now how the Port J1 is called in Labview Software....so thats the big question Smiley Sad
(3,259 Views)
HI,
did you look into this?
http://forums.ni.com/t5/LabVIEW/sbRIO-9631-and-communicating-using-RS-232/td-p/1405868
You have to have installed the NI-VISA and NI-Serial RT on your sbRIO.
then you can communicate over the COM-Port.
Which sbRIO do you have? I think there was a typing mistake in the subject.
Anna
Anna Vogl
(3,239 Views)
my Rio is SbRio9642....
Thank You so far, I hope I will take it now Smiley Very Happy
(3,229 Views)
