Arduino with labview using linx
I am using Arduino with labview and burning the program into arduino using makerhub linx. the problem I am facing is the delay in reading the input data from arduino to labview of about 10 seconds. looking forward for possible solutions.
Message 1 of 13
(6,138 Views)
Hi kash,
I guess the problem is in your software.
You need to debug your software to find and eliminate that problem.
Message 2 of 13
(6,125 Views)
Well without seeing your code all we can say is you are doing it wrong.
Beyond that your guess is as good as ours.
=== Engineer Ambiguously ===
Message 3 of 13
(6,115 Views)
My guess is you are closing and reopening the reference between each read.  This causes lots of extra delays and a better method is to open once, read many times in a loop, then close once.  Just a guess though and as others said posting the code would help with that.
Message 4 of 13
(6,110 Views)
Sounds like a timeout error to me.
But who would know without seeing any code posted.
Message 5 of 13
(6,097 Views)
Kind of fun to guess without source code 😉
But at 10 seconds, it's almost certainly a VISA Read timeout. Add a termchar to the end of your data stream from the Arduino. I can't recall if VISA Read's default timeout is 2 seconds or 10 seconds (and it may vary by device/driver? I'm not sure).
Message 6 of 13
(6,087 Views)
I am sharing the snapshot of the code. the problem i feel is with linx open serial which is taken time. the reason being, there is a delay in execution of the first sequence.
Message 7 of 13
(6,073 Views)
i think the delay is due to the initialisation of the linx.  Now the problem is, I am also actuating the actuator via digital write through linx and due to delay in acquisition, the actuator does goes to the extreme position till it start acquiring the data.
Message 8 of 13
(6,071 Views)
I think you should show us your code so we can actually help you.
Message 9 of 13
(6,061 Views)
hi,
 Please see the attached code. here i am using makerhub linx for the acquisition of data. To enter the sequence, it takes times.
Message 10 of 13
(6,048 Views)
