Are Property Nodes supported in PDA Module 8.0/8.2 versions?
Are Property Nodes supported in LV PDA module 8.0/8.2 versions?
Page 34 of "Getting Started with the PDA module 8.0" does mention Property Node under the heading, " Newly Supported VIs and Functions". Also, http://zone.ni.com/devzone/cda/epd/p/id/3973  mentions that "LabVIEW PDA 8.0 added support for property nodes".
But I always seem to be getting an error (the run button is broken) as soon as I add a property node to a PDA VI. The error I get is " Property Node: Not supported for current target". I am using Pocket PC 2003 SE Emulator in PDA module 8.2.
-SS
(6,910 Views)
You can find this information in two places
1) NI.com : http://zone.ni.com/reference/en-XX/help/370642D-01/lvpdatpchelp/pda_properties/
2) LabVIEW Help in your software:
If you get this error then we don't support this property yet. You can also make a product suggestion.
Biren
LabVIEW PDA & Touch Panel R&D
(6,897 Views)
Thanks Biren.
-Shruti
(6,856 Views)
