Are bundle and unbundle expensive operations
Are bundle, unbundle, bundle by name, unbundle by name expensive operations if used in a loop. I am using a bundle to pass/obtain data to a subvi. So I need to unbundle the wire pass them to a subvi and then bundle the wires that come out of the subvi and feed that into a shift register. I cannot do the bundling and unbundling outside because of the shift register which I need.
Thanks.
(3,217 Views)
Accepted by topic author sharmaa
Thanks.
Not necessarily. It depends on what you do with what you are bundling and unbundling.
I think the best resource I can offer is this thread where Dr. ONeill and I investigate that very question over a series of days.
Warning:
That thread is NOT lite reading. Take it bit by bit and take frequent breaks to avoid cerebral overload.
Ben
(3,212 Views)
Well, it is more expensive than NOT doing it. But let me say this: using clusters to pass ALL of the data around in state machines and two/from VI's is extremely common and often recommended. I carry around arrays or references in clusters, channel setups, tasks, error texts, and so on, in loops that run at 5mS for 24/7 and have never experienced a problem associated with my use of clusters.
My thought is, compared to the alternative of having two dozen shift registers with single items in them or one S/R with a cluster - you might have to be on a real Time target to see a performance hit.
Super-Clusters might be another story.
Richard
(3,209 Views)
