Are subvi of reentrant vi need to be specified as rentrant?
It's the first time I need to use reentrant VIs so I'm not familiar with this. I want to test four unit in parallel, so I have 4 clones of the test engine vi (not called dynamically). The test engine vi contains a lot of subVIs, should they also be made reentrant?
Ben64
Message 1 of 9
(3,792 Views)
It depends on the need. If you are using USR (Uninitialized Shift Register - More info ) in those sub vi's and want to use the data differently for the different units then make those vi's clone but generally its not required to make the sub vi's clone.
Message 2 of 9
(3,789 Views)
I'm not using any AE in the subs, I will try without making the subVI reentrant.
Thanks.
Ben64
Message 3 of 9
(3,778 Views)
Ben64
But I am Damn sure you will use it in the future.
Message 4 of 9
(3,776 Views)
I've already been using AE a lot for a while, but not in this case.
Ben64
Message 5 of 9
(3,773 Views)
You can use non-rentrant in a re-entrant VI but if both instances are trying to use the same non-reentrant sub-VI, the second will hang waiting fo rthe first to finish using the sub-VI.
If you are talking LVOOP and recursive classes... then it appears everything has to be re-entrant. Well at least I LV insisted I make them all re-entrant.
Ben
Message 6 of 9
(3,760 Views)
Ben
Thanks Ben,
In this case it is not LVOOP and recursive classes. I want to test 4 units in parallel so I have 4 copies of my test engine VIs. From what you're saying it seems I should made some of the subVIs reentrant to avoid the other instances to hang. One of the sub is a test state machine so probably this one also will have subVIS to be made reentrant.
Ben64
Message 7 of 9
(3,757 Views)
Sounds right.
Here are a couple of tip if you run into a situation where you you would love to use an AE in that scenario but can't because the two different re-entrant instances would interfere with each other.
Option 1
Use Call by Ref nodes to invoke the AE and open a new instance of the Ae for each top-level re-entrant VI.
Option 2
Use a DVR to store the data (one for each top-Level) and pass the RDV ref to a pseudo-AE and let act on the DVR data instance instead of data from its internal SR.
Option 3
Use LVOOP methods instead of an AE, and keep the Class data in the Top-level re-entrant.
Ben
Message 8 of 9
(3,754 Views)
Thanks Ben
Message 9 of 9
(3,746 Views)
