Are there any VI's that emulate NI DAQ boards?
Can anybody tell me if LabView has DAQ board emulation VI's? I would like to create a program to run on a DAQ board without actually having the board.
Thank You,
Molana
(2,606 Views)
The latest version of NI-DAQ (7.4) allows you to simulate DAQ boards to allow you to run a vi without the needed hardware. You may want to look into this if that is acceptable for your needs
(2,594 Views)
Thank You. I'll look into it.
Molana
(2,590 Views)
DAQ 7.4 is a free download, assuming you have a high speed internet connection as it is about 800Mb, zipped! It will do a partial simulation of many of National Instruments current line of DAQ boards, does not provide particularly "interesting" signals from the simulation, but it does allow you to develope some of the code after the DAQ that you couldn't easily do before.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,577 Views)
