Are there any filteres on the analog output of the 7831r?
I can't wire it - it says "Polymorphic termianl cannot accept this data type". What am I doing wrong?
Message 11 of 16
(909 Views)
Try placing an array constant on the block diagram.  Then place a double constant into that array constant.  Then wire it to the TDMS read like so:
Brandon Treece
Message 12 of 16
(901 Views)
Hi Scott,
I changed the data type but it didn't help - I still can't transmit at 1M. Any other ideas?
Message 13 of 16
(891 Views)
You may want to open up a service request so that we can look further into this situation, but off the top here on the discussion forums I can't see any reason off hand that you can't transmit at 1M
Message 14 of 16
(881 Views)
How can I open a service request?
Actualy I'm facing several issues which are critical for my project and very urgent.
Message 15 of 16
(875 Views)
you can go to ni.com/support and on the right hand side there is a link to "phone an engineer"
Message 16 of 16
(870 Views)
