Are there differences between the 185095-02 cable and the 185095c-02 cable?
We've been using the 185095-02 cable for quite some time for a product we sell, and recently started receiving the "C" versions of the cable.  At least one pin (Pin 23) is not connected on the "C" version.  Is this supposed to be the case?  What are the other differences that we can expect?
Tyler
(4,780 Views)
Hi Tyler,
I haven't been able to find enough documentation about the previous version to compare it to the version "C". I will look into this further and get back when I find this information for you.
Mark E.
Precision DC Product Support Engineer
(4,745 Views)
Hi Tyler,
It appears that the only change that has been made since the beginning of this cable to the revision C was the color. All the pins have the same connections, according to the engineering drawings. Are you seeing pin 23 not being connected on multiple cables or is this an isolated problem? It may be that you just have a bad cable and need to contact us for a replacement by visiting www.ni.com/contact and speaking to a customer service representative.
Let me know if you have further questions.
Mark E.
(4,731 Views)
