Are there multichannel lock-in toolbox files I can download for Labview 7.0?
I recently downloaded the Multichannel LockIn-DAQmx library from your website, but when I try to open the DAQmx file I get the error message "VI version 7.1.1 is newer than VI verson 7.0".  Is there any way to make available files that would work w/ my v 7.0?  Is it just a matter of opening the files in 7.1.1 and resaving in a format amenable to v.7.0?
(3,175 Views)
I can be saved back to 7.0 by someone with 7.1.1 I am not sure if there is any reason why it would not work with 7.0. Post the library or a link to it here I am sure someone will save it to 7.0 for you.
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
(3,167 Views)
That would be great.  Here's the link:
Multi Channel Count Lock-In Amplifier with DAQmx
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=042319214C65627AE0440003BA7CCD71
(3,164 Views)
See if this works.
Andrew Alford
(3,159 Views)
It loads now... thank you so much for your help!
(3,151 Views)
Your welcome don't forget to rate the posts that help you out.
Andrew Alford
(3,147 Views)
