Arithmetic mean
Hello!
Does anyone have the OpenG Arithmetic Mean VI (at least the one for 2D array). I have installed the OpenG Numeric package, but cant find it there.
Or maybe even better, does anyone have a VI or a good solution for calculating the mean of columns in a 2D array?
Greetings
Kristoffer
Message 1 of 20
(8,988 Views)
does this Help?
Message 2 of 20
(8,981 Views)
Thank you!:)
Just a further question: Is there any possibility for also using a time column when calculating the mean? Such that the code take into account the length of the samples as well (given that the sample time is not a fixed value).
Greetings
Kristoffer
Message 3 of 20
(8,945 Views)
There are no native functions that I am aware of (not saying it does not exist).
How are your time samples taken?
ie:  seconds since last sample..?
timestamp?
For instance, if it is a timestamp, and they are in an array, you can take the difference from the previous element, and then calculate the mean.
Message 4 of 20
(8,933 Views)
As it is now it is an array of type string, but I am trying to convert the type of the whole array into timestamp. I was then thinking of doing just as you say, taking the difference from the previous element. Do you have any good examples of a loop where this is done?:)
Greetings
Kristoffer
Message 5 of 20
(8,918 Views)
This will do if the timestamp string is local specific
If your timestamp string is in a different format
Here is a link to the Formats you would use
E.G. %<%Y/%M/%d %I:%M:%S %p>T  would create a timestamp from "2012/04/10 2:04:51 PM"
Message 6 of 20
(8,892 Views)
Broken Link-  Don't know what happened
Here
Message 7 of 20
(8,886 Views)
Hello!
I have transformed the 2D array from string to timestamp! I was more thinking of a good structure for taking the difference from the previous element when the array is of type timestamp.
Greetings
Kristoffer
Message 8 of 20
(8,860 Views)
nothing simpler
Message 9 of 20
(8,854 Views)
Thanks again. But, that will be for a 1D array if I'm not wrong? My array is a 2D, so i guess i'll need to either add a loop for iterating both columns and rows or something?
Greetings
Kristoffer
Message 10 of 20
(8,850 Views)
