Array Cluster of booleans
How do I make the Boolean buttons act like a radio button in this Cluster array.
If the user clicks on one of the buttons I want all other buttons to be false.
Is this the right control to use of is there something better.
I am trying to make a list of tests and the user will click on the Boolean to run the desired test.
Message 1 of 9
(5,594 Views)
it is not good idea to use array of cluster just to select tests to be run. I am not saying it is impossible but first it will not look good and you will need to manage update/create array each time user select different test.
how about using table or list, with proper marking(tick and uptick) ?
Amit
CLAD
Message 2 of 9
(5,579 Views)
I cannot open your code to see what you have done but all you need to do is place down a radio button group, right click each control inside it and replace with the type of boolean you want to use.  No code necessary.
aputman
Message 3 of 9
(5,559 Views)
Radio buttons are static always the same number of tests.
This is not what I want I want the user to be able to define how many tests they need.
Thus use an array.
Message 4 of 9
(5,550 Views)
The easy answer: Use a radio button.
What you're probably after: Use a Value change event on the array and set all but the current button to false.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 9
(5,532 Views)
Message 6 of 9
(5,514 Views)
Unless you have additional cluster elements, a plain Boolean array is all you need. I guess you have other cluster elements, such as a string to give the test a name, for example.
Is the number of tests known from the beginning or can the number of available test change during the run?
Personally, I would use a simple listbox (selection mode = 1 item), filled with the various tests. You can sense e.g. double-clicking an entry to run that test.
Message 7 of 9
(5,499 Views)
This example you gave me works great. 1 more question. How can I make the event structure ignore anything but the Boolean (test button). See attached file.
Message 8 of 9
(5,344 Views)
Unfortunately, you cannot do that with an array of clusters.
As an aside, you can greatly simplify that while loop in your event case by using a FOR loop.
Message 9 of 9
(5,336 Views)
