Array Element Change Style
Here I have one application where I need to change the font of first element in 1D array.Is that possible programmatically ?
(1,479 Views)
Accepted by topic author Dhruv1140
Hi Dhruv,
No. In an array all elements share the same properties!
Suggestion:
When you use a Table or Listbox indicator to display your array data then you can set individual properties for each item in the table/listbox…
(1,458 Views)
