Array Manipulation
Hi GerdW
I have attached a Vi which converts 2 ways Mine is the messy graphics at the top of the vi the other I was helped with from the forum these originally used 4 bytes but now there are only the bottom 3 bytes of the array array 0 not used 1,2,3 make up the U32 I am only  interested in a 20 bit value MSB array 1 and LSB array 3 the bottom 4 bits in array 3 (0,1,2,3) are not used.both these graphics work and give the correct answer.
Best Regards
David
Message 11 of 15
(2,337 Views)
Filter out the unimportant bits with AND.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 15
(2,315 Views)
Hi David,
another way to get your 20 bits:
Message 13 of 15
(2,312 Views)
Hi GerdW
Sorry I meant 20bit 2s compliment with the vi you gave me earlier (please see attached)ie. working on an array without a for next loop.
Best Regards
David
Message 14 of 15
(2,295 Views)
Hi David,
apply the last snippet on the array of I32 values you get from the first solution…
LabVIEW gives you tools like loops and autoindexing - and it is a feature-rich programming language!
Message 15 of 15
(2,288 Views)
