Array Problem!!!
Hii
 See i am having ane 2D array which has Row ID and Files Names....
 I the file names when ever Looping Operation Preforms the Corresponding Row Id Will be a empty string..
 But i my main Vi I will use Only the File Names ... but the Corresponding Looping values get vary...
 Now i want like what i have attached it....
(2,934 Views)
I assume you ware mistaken and made some write errors in the 'From Loop...' elements.
If you want to do this you will need to use index array.
Ton
My LabVIEW Ideas
(2,929 Views)
Karthikeyan,
This one looks like a repeat of this post
Do stick to one post for your query.
Continuity and getting a solution to your problem would be much better, if u do so
(2,918 Views)
