Array initialization problem
GerdW a écrit :
Hi Pavel,
without error chain it may work or it may fail - it's a typical race condition!
By now you should have learned to THINK DATAFLOW!
Hi GerdW,
It seems that Local Variable isn't concerned by "race condition". Am I right ?
Message 11 of 12
(1,361 Views)
It isn't concerned but that doesn't mean it can't cause them!
In this case I would either put a faux structure around the Local write and connect an output wire to the loop or go back to a property node and wire up the error cluster.
Using a local variable like this is a typical race condition problem.
Pseudoqquote:
If you don't work toward removing race conditions you'll regret it.  Maybe not today, maybe not tomorrow but soon and for the rest of your life.
Message 12 of 12
(1,343 Views)
