Array of Booleans
Is there a way to know which toggle switches were selected on a frt panel with 6 or so  Sws.  The sw's select a particular test.  I saw an example in the discussion grp to find out which SINGLE element in the boolean array was high ( use Build an array then search 1 d array) .  What if I have 2 or 3 or 4 etc that were selected.  How can I tell boolean sw associated w "turn on pwr suppl1 and Turn on PS 2 " was selected?
Clint
(4,053 Views)
The way I would do this usually is through the event structure, but you can use a shift register and check equality between itterations as well.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,050 Views)
Convert the boolean array to a number.  If the first and third switch are on, your result will be five.
Jim
(4,046 Views)
Hey Clint,
Paul and Jim have some good suggestions. I agree with Jim though, creating a Boolean array and converting it to a number is a clean way to do what you are attempting to do. I have created a small example that shows how to do this in LabVIEW 8.6. I have also included a picture of the block diagram, in case you have a different version of LabVIEW.
Let us know if this helps.
Ben
Applications Engineering
Hope this helps.
-Ben
WaterlooLabs
(4,009 Views)
XOR old and new values. Everything True has changed.
Ton
My LabVIEW Ideas
(3,999 Views)
Another approach would make the array of booleans a cluster of booleans with an appropriate name for each.
Then set up an event for each boolean. The events will be serviced in the order the buttons are clicked.
Ben
(3,992 Views)
Thanks everyone.
I played w Event Structure (ES) and I think I got that to work.  I worked off of an example from the Discussion Grps posted back in 2006.  When I 1st posted I didn't think you could get an ES know  which toggle SW "Changed Value".  I thought it only let you know a toggle sw ( Boolean) chg'd.   It does, and the chg value is perfect for what I want to do.
Again, Thanks.
(3,954 Views)
