11-28-2007 02:59 AM
11-28-2007 03:05 AM
11-28-2007 03:35 AM
11-28-2007 03:40 AM - edited 11-28-2007 03:45 AM
11-28-2007 04:51 AM
11-28-2007 05:02 AM
Meenatchi wrote:
If i didnt so i will have 16x5 controls in my front panel and i have to put 16 event cases for each combo box to do the enable and disable of controls..
11-28-2007 05:11 AM
11-28-2007 05:25 AM
if you have "only" 16 clusters of indics, knowing in advance it will not change, you can group them into one cluster.
that mean, you can access programatically all indics easily, and define behavior pattern without hassle. also, if the operations are similar you can use a single event cases for several indics, as Partha said.
i will set up an example later on and post it.
11-28-2007 05:40 AM
11-28-2007 05:48 AM
Meenatchi,
May I know why you want to keep them as Cluster controls? ![]()
You can simply keep them as normal controls & building their references into an array to do the Enable/Disable or Visible/Invisible operations all in a single stroke using a For loop -->> Generic Property/Invoke node.
This way will be very much helpful when your application grows to a bigger size in terms of COntrols/Indicators in future, whereas Array of Clusters of Clusters will be really painful when you want to set properties for individual elements all along your UI.
