Array of Occurence references
Hi everybody,
i need a dynamic array of occurence refnums.
If using a FOR-LOOP within an Generate Occurance.VI i will get a array of
identical refnums.
If i use multipe Generate Occurance.VI´s with BUILD ARRAY it works.
But this is´t not dynamic.
Any suggestions????
Thank´s
(3,360 Views)
Create a reentrant VI that outputs an occurence refnum returned by Generate
Occurence function. Every time you need a dynamic refnum, open a reference
to the reentrant VI and call it by reference to get a new refnum. The
occurence refnum will be destroyed when you close the VI reference that
created it. I suggest you make a cluster {occ. refrum, VI refnum} to keep
them together so when you are done with a occ. refnum, you close the VI
refnum.
Jean-Pierre Drolet
"Andreas Franz" a écrit dans le message news:
3a2fa20d@newsgroups.ni.com...
> Hi everybody,
> identical refnums.
> Any suggestions????
> Thank´s
(3,360 Views)
