Array of boolean to single boolean
Good morning all,
I am looking for a quick and dirty way to evaluate a entire 1x19 boolean array into a single boolean true/false.   Several ways to be true, but only one way to be false.   Any suggestions?
Zach
(16,008 Views)
Accepted by topic author super-neuron
Hi Zach,
see the "Or Array Elements" function.
Mike
Message Edited by MikeS81 on 08-27-2008 05:54 PM
(16,006 Views)
Do you mean a simple "OR", i.e. if any boolean is true then the output should be true?
In this case, just use the "OR Array Elements" from the boolean palette.
Daniel
(16,004 Views)
Money!   Thank you!
(15,996 Views)
