Array of cluster or vice versa ? Help !
Please take a look at the attached VI.
Its purpose is to transfer datas stored in 9 deported automatons (each one
symbolized by a letter : A,E,F...).
For this I must send an interrupt on the serial port of the PC (a char
string like "AAA", "EEE"... in fact 3 times the letter of the automatom to
transfer).
How can I handle easily the selection of the different automatoms chosen by
the user ???
Please help !!
[Attachment Transfert.vi, see below]
[See first answer for additional information]
(2,864 Views)
[Attachment(s) for question]
(2,864 Views)
Renevier:
If you wish to keep the large boolean controls on the front panel, you
could place them all in a cluster and wire it to a "cluster to array"
function. Wire the boolean array output to a "boolean array to number"
function and then wire this function's integer ouput to a case
structure. You'll then need to set the case values to powers of 2 to
make your selections (0 (default) = no selection). However, you will
be able to send only one command at a time with this setup.
* Sent from RemarQ http://www.remarq.com The Internet's Discussion Network *
The fastest and easiest way to search and participate in Usenet - Free!
(2,864 Views)
