Array of clusters accessing an element
Hi everyone,
   I would like to know if someone knows how to access the next: Lets say I have a cluster of 3 numerical controls and one string field. Now I put this cluster inside of an array to have 3 times the custer. My question is how I can access to (for example) the string field of the third cluster and write something inside? Of course programatically.
Thanks in advance
(1,845 Views)
Get the desired element value with Index Array, modify its content (Bundle or Bundle By Name), then use Replace Array Subset to place the new value back into the array at the same position.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(1,833 Views)
or use the InplaceElement structure two times...
(1,830 Views)
Accepted by topic author Necsuss
Some variations on the theme:
(OOPS, third element should obviously be 2, coffee hasn't sunk in yet)
(1,827 Views)
Thanks, that worksfor me. The part with the unbundle by name it is the trick !!!
(1,811 Views)
